  #20
Old 05-19-2010, 06:39 PM
You always find more to do, don't you? With the dash it's something I don't every want to take out again, so I need to take care of anything I can while it's out. Like the kick panels and vent pulls. I think they installed the driver's side kick panel first thing on the assembly line then the rest of the car around it. You have to remove the dash, then the e-brake pedal, then the fuse block. I worked around the high-beam switch but it was in the way too.
Almost done, maybe I can get the dash back in tomorrow. Check all the connections, don't want to see any smoke, then we're good to go.
