Old 07-05-2010, 04:38 PM
cabbage cabbage is offline
Default new guy type question
wondering if a 68 chevelle will fit in my garage width-wise? anyone willing to measure the width of their 68 or so chevelle?
Old 07-05-2010, 04:47 PM
Can't answer your question,being that I have a 70. But I can welcome you to the site!
Old 07-05-2010, 05:59 PM
Chevelle_Nut's Avatar
Chevelle_Nut Chevelle_Nut is offline
They are no wider than a full sized pickup but remember the door are thicker than newer vehicles.
Jon Hart http://www.coolharts.com
72 Chevelle Malibu / 69 Chevelle Malibu 4 Door
72 Chevelle Malibu Father/Son Project-- In Pieces
Old 07-05-2010, 06:07 PM
I have a 70 as well. My garage is a typical 2 car, 2 doors, around 9' wide, with a foot or so of brick in between them. Also have a steel post in the middle of the garage, there are bedrooms above. My Chevelle fits no problem, not a lot of extra room for working on it but it fits fine. A 68 is has basically the same frame but the body may be few inches narrower. I'll measure the car itself.
EDIT: Ok, my car is just over 6' wide, roughly 74" and welcome to the site.
Old 07-05-2010, 06:17 PM
Was that from fender to fender or tread width?I'm 5' 11",I shall lay under my car and have Maureen check,keys in my pocket of course.
Old 07-05-2010, 09:16 PM
Rank Rank is offline
.... is this a trick question??
Old 07-05-2010, 11:31 PM
Also welcome to the site.
Old 07-06-2010, 02:33 PM
well i've got a 94 inch opening to squeeze through....including mirrors should be able to do that
Old 07-06-2010, 04:26 PM
You should be ok, tight but ok. I slid a tape measure under the car so the measurement is close to the widest part of the doors.
Old 07-06-2010, 04:28 PM
My daughter could easily get a 95" car through a 94" opening.
