Old 08-14-2010, 05:18 PM
Warputer's Avatar
Warputer Warputer is offline
Question Powerglide swap options.....
Took the car out on the Interstate for the first time today & at 70 mph +, she turns way too many rpms. I believe the rear is a 3.73 ( haven't raised the rear to count rotations yet ). My question is .....would a TH350 be any better with highway speed rpm's versus this 2 speed Powerglide? I realize there is no OD in the TH350 though.
Old 08-14-2010, 07:24 PM
Rattler's Avatar
Rattler Rattler is offline
Final output on all non overdrive transmissions is 1:1. There's no difference at all between them. As said above an overdrive trans or a higher ratio rear end are you best options.
Old 08-14-2010, 09:24 PM
I've been playing with the option of putting a 700 tranny in my 70, but they are fairly pricey but give you the overdrive. You will have to get the drive shaft shortened also.
