i have a 67 rag top project i need to know how to wire the power to the top switch
Seems this has set for a while...... I know that on my '69 there was a 10awg wire that connected to the starter (same post as + batt cable). Ran up to a breaker mounted near the master cylinder. I 'think' it was a 30A breaker. Wire went from breaker to common post on top switch. Rear harness connected UP and DOWN between switch and motor/pump.
One source is American Autowire p/n 04850166 sold by many vendors. Last edited by dbradley; 09-13-2010 at 12:30 PM. |
On a 68 the power wire goes from the horn relay power tap along the driver fender wire harness to the 30 amp breaker mounted above the brake cylinder then through a firewall hole to the switch.
