Old 11-03-2010, 08:26 PM
grumpy's Avatar
grumpy grumpy is offline
Administrator Bowtie Member
Default Tire and rim sizes
Rim and tire choice has really been driving me crazy. I know that to get the best fit, we really should measure everything. After looking at many magazine and cars, this is what I was thinking of trying.
Nitto 555 Tires
Rear 255/50/17
Fr 245/45/17
Rims Torq thrust M
Rear 17X10.5 7.5" backspace or 17X9 6.75 backspace
Fronts 17X8 4.5" backspace or 17X9 6.75 backspace.
I really want a tire that has some side wall to it.
Which of these do you think would work best or, maybe suggest another size. Thanks
Dave
Dave
Old 11-03-2010, 10:57 PM
Rank Rank is offline
10.5s without tubbing.... is that possible??
I like the Nitto tires they have served me well in the past. I just put Khumos on the vette .... the jury is still out on those.
Old 11-04-2010, 06:12 AM
grumpy's Avatar
Thats why I am trying to find out.
Dave
Dave
Old 11-04-2010, 09:00 AM
Seems like alot of meat to stuff under the wheel wells, especially using seventeens. I am waiting for the answer myself since I wanna put the widest tire I can on my 70 ... you gots a stock rearend and drums?
Old 11-18-2010, 09:18 PM
dbradley dbradley is offline
I've used this site with success to find 'maximum' tire/wheel sizes. As you'll see, they have guaranty sizing that will fit. Just start with "car" on left and follow prompts. You can force wheel size, tire size, etc and it will let you know if it fits. I did see a 17X9 with 5.3" BS for the rear....Direct Fit, And a 17X10 with 6.1" BS with a 275-40
http://www.rimsntires.com/shopcart.j...=erase&itemn=0
Old 02-27-2011, 08:25 PM
grumpy's Avatar
After poking around I think I like the Nitto Invo's in the same size above better. Would 19X8 fronts, and 17X9's fit without any rubbing issues ? Thanks
Dave
Dave
Old 02-28-2011, 08:08 AM
Are your quarters rolled or trimmed? If so, you can fit an 11" wide wheel with 6.125" backspace. *only works with 17"+ wheels - smaller diameter wheels won't clear the shock mounts* Double and triple check your measurements to get the backspace right though.
With 10" wheels, you'll want 5.5" backspace.
