Old 11-04-2010, 06:44 PM
Default Correct finishes for under hood and suspension.
Looked at a few guides,but they are awful generic.Need to know under hood,inner fenders,cowl and firewall glosses. Also need to know the different finishes for front suspension pieces. If any of you guys know 70s and would be so kind as to take the time to help me I would appreciate it! Like I said before,I'm doing this once and I'm doing it right.
Old 11-04-2010, 07:19 PM
I haven't talked to Ray, rbarnes, in a few weeks but I'll talk to him this weekend and see if he can help. I'm sure the underhood colors/gloss are the same for 69 and 70 and he knows exactly what they should be.
Old 11-04-2010, 07:22 PM
I'm only going to say this once....the color is BLACK
Old 11-04-2010, 07:30 PM
I wish it were that easy.
Old 11-05-2010, 01:29 AM
Rank Rank is offline
you gots your flat black, semi-gloss black, wrinkle black hammer-tone black, satin black, low sheen, high sheen, in-between sheen, etc etc, .... just use the krylon barbeque black, you cant go wrong! LOL
Old 11-08-2010, 05:30 AM
Here's one guide I used from Robs site http://www.1969supersport.com/
rear brake backing plates etch prime gray #sxa1031 and eastwoods detail gray
front control arm shafts napa zincrom primer #7222 and napa iron/block cast #7250
rearend cover etch prime gray #sxa1031 and sema promax #61023 semi gloss black
contol arm shims #sxa1031 and eastwood detail gray
tie rods napa zincrom primer #7222 and napa iron/block cast #7250
tie rod clamps #sxa1031 and eastwoods detail gray
steering gear box napa #7222 and napa #7250
steering gear small cover eastwoods silver cad
steering gear ring and nuts sem promax semi gloss black
driveshaft straps and bolts #sxa1031 and eastwoods detail gray
front wheel grease cups #sxa1031 and eastwoods detail gray
ends of drive shaft #7222 and #7250
universal joint clips and clip area plasti-cote clear, small bottle brushed on
transmission #7222 and # 7250
transmission side cover eastwoods silver cad
driveshaft plasti kote non sandable primer and eastwoods detail gray
hurst shifter plate valspar antirust flat black
front springs sxa#1031 and eastwoods detail gray
front stabilizer bar sxa#1031 and eastwoods detail gray
rear springs sem #15031 landau black flexible paint
Old 11-08-2010, 09:27 AM
Thanks Ray.
Old 01-04-2011, 12:50 PM
Bowtie-Bri's Avatar
Hey Gary,
Not to confuse you but I thought I'd post this up as another point of reference. http://www.chevelles.com/shop/resto_5.html
Brian
