Old 06-20-2011, 10:08 AM
Thunder Thunder is offline
Default 68-72 upper & lower Tubular Control arms and Braces
PMT Fabrication 68-72 A-Body Upper/Lower Rear Trailing arm & Brace set.
Upgrade from you stamped steel OEM suspension to a bulletproof tubular design. Eliminate Wheelhop and increase traction by drastically reducing flex and maintaining geometry. Polyurethane bushings compliment the tubular design in a durable high-gloss black powedercoat, 2 housing bushings included, grade 8 hardware and sway bar provisions. With Lubrication fittings.
****Plus you also get…
The perfect compliment to the trailing arm kit! These Trailing arm mount braces are adjustable and designed to brace the upper crossmember triangulating the whole rear for much greater strength, stability and control. Mounting hardware is included. In a durable high-gloss black powdercoat finish.
These are Brand New, never installed. This is a $400 value, all for a Buy it now price of $350. Don’t miss out on this great deal!!
