Old 06-28-2011, 10:47 PM
Default Console Question
How much carpet do I need to cut out under the console. I know I need to cut around the 4 speed hump, but not sure about the rest.
Old 06-29-2011, 06:53 AM
Around the opening is all you 'have to cut'. I slit mine down the center from the front of the console all the way to the rear of the carpet. This allowed me to pull it in tighter around the trans hump, since the slit is under the console it's not visible. The preformed trans hump in the carpet was too big/wide and wouldn't lay flat against the metal until I slit it.
