Old 08-12-2011, 10:14 AM
Berg's Avatar
Berg Berg is offline
Default 1970 Chevelle Malibu in NY for sale
1970 Chevelle Malibu with 400ci bone stock small block out of 1971 Monte Carlo, TH350 believed to be original, 10 bolt open rear power drum brake car. It has front drums on it with mostly new front steering parts. The car is now black but originally code 45 mist green with code 48 dark green interior. Vinyl top car that needs a restoration. Car has most of its original parts but it needs work to be a driver. Cowl panel, Quarters, trunk panel, lower fenders, decklid, valance and hood could use replacements. Has rot in floor pans. It has a new master cylinder but it really needs all new brake lines and hoses, I planned on installing factory front discs. I have GM spindles with caliper brackets and dust shields, new rotors, bearings, seals to go on the car along with a 12 bolt rearend with a series 4 carrier that will be offered as well. I have a set of bucket seat cores that need to be restored but no headrests and the drivers seat is missing the tracks. The car comes with an L98 350 with 1.94/1.50 swirl port heads lightly ported with comp cams 168 camshaft, with double roller timing set, hardened pushrods, comp springs, screw in studs, melling oil pump and some other odds-n-ends. I have another drivers side door for misc parts that will also be offered. I have the code 48 door panels, package tray, carpet, and some other parts for the interior. It has stock sweep dash, I'm asking $5,500 negotiable. I'll be away until Wednesday but if you want to email me and ask any questions I'll answer them when I get back.
E-Mail: [email protected]
84 K5 Blazer 350/SM465
75 K5 Blazer 355/SM465/8 lugs
Old 08-12-2011, 10:16 AM
Berg's Avatar
Old 08-12-2011, 10:18 AM
Berg's Avatar
Old 08-31-2011, 11:11 PM
oliver83 oliver83 is offline
I'm looking for some Chevrolet parts for my Malibu project car, so would you consider selling it by parts?
Tags
1970, chevelle, complete, malibu, parts.
