Old 10-09-2011, 08:33 PM
Default My Elky's Turn
Its almost time for my El Camino to have a chance to get driven some and let the convertible get some much needed rest and cleaning. The Elky is running very rough partly due to old points and condenser and probably bad gas as well by now .Once I remember how to change and adjust the points I'll see about driving out the bad gas and getting her some fresh.Then it will be time for cleaning the old girl up and just driving her awhile.
Old 10-09-2011, 08:50 PM
Swap that points distributor for a HEI.
Old 10-09-2011, 09:26 PM
Only two screws to change points, if you have a dwel meter it helps to set points with it. We used to used them all the time back in the seventies. In fact I still have one in my tool box, wonder if it even works anymore.
Old 10-09-2011, 09:41 PM
I can't remember how to set points,or reline drum brakes.
Old 10-11-2011, 08:20 AM
Berg's Avatar
Berg Berg is offline
If you aren't overly concerned with originality I'd say toss the points and put an electronic conversion kit on your current distributor, step up to a Blaster II coil and bypass the resistor wire. Keep all the stuff you take out of it in case you ever feel the need to go back to original. The nice thing about the electronic ignition is the car can lay around or get driven every day and there really isn't much maintenance other than a cap and rotor every now and then. I used to not mind points but on my last Chevelle I spent more time adjusting and cleaning them than I did driving the car since it sat so much
84 K5 Blazer 350/SM465
75 K5 Blazer 355/SM465/8 lugs
Old 10-11-2011, 09:43 AM
I would like to do an in cap conversion sometime in the future but Im currently on a limited budget and I already have the points and condenser for this time.
Old 10-11-2011, 08:19 PM
Time for the vert to get some rest eh ? That car treats you guys so well, you better clean her up and treat her good.
Old 10-12-2011, 07:30 AM
Im going to clean her up on friday so that we can go to the last local cruise in and then take Chase and his lady friend out to dinner for my birthday.
