Old 02-05-2012, 04:35 PM
Default alternator bracket question
so i said to myself everyday i want to do something to my chevelle even as small as putting my hand on it..lol so this weekend after cleaning out the garage i came across two parts one was the fuel pump and push rod and the other was the alternator bracket. I got the push rod in its easy now that i know how to do it, installed the fuel pump done. went to bold on the alternator bracket and then i got confused. i got them on but it just doesnt look right here is the pictures
is it suppose to bolt on to the intake manifold and the water pump?
Old 02-05-2012, 08:17 PM
Here's some pictures from mine. You will need to change the manifold bolt to a stud style bolt.
Old 02-05-2012, 09:53 PM
o man where am i going to find a stud style bolt like that? thanks again for showing me that but i guess i need to research some more then
Old 02-05-2012, 11:32 PM
Mounting kits are available, Here's the stud but need to make sure it is the correct size. I've seen some that are wrong. My intake has 4 of them on it on for alternator, engine lift bracket and vacuum brake booster tube.
http://www.ss396.com/mm5/merchant.mv...RMONICBALANCER
Old 02-06-2012, 06:51 AM
thanks man i will give them a call to get one and order a couple of small things while i am at it
