Old 04-01-2012, 05:05 PM
Monte666's Avatar
Monte666 Monte666 is offline
Default Engine backfires under full throttle
Had my car inspected last week found my valve covers loose when I got it back and now it's backfires under full throttle but only in gear any opinions or help would be appreciated I know there are alot of smart people on here
Sent from my HTC Sensation 4G using Tapatalk
Old 04-01-2012, 05:48 PM
I would take it back to the place that inspected it, did they do anything to it?
Old 04-01-2012, 09:42 PM
Did the vacuum lines get hooked back up or do you have a cracked one?. Almost sounds like the distributor is not advancing correctly when under a load.
Old 04-02-2012, 12:34 PM
Monte666's Avatar
I took it back to my normal shop this morning they think big o changed my timing crossing my fingers
Old 04-02-2012, 12:51 PM
Monte666's Avatar
They changed my plugs at big-o could it be that they are gapped wrong
Old 04-02-2012, 05:05 PM
Unless the gap is WAY off it shouldn't cause a backfire. Idle's smooth I assume? As Ray said, maybe timing or vacuum lines or timing.
Old 04-02-2012, 05:52 PM
Monte666's Avatar
I did just change carburetors from a old holley to a new performer ill check my lines
Old 04-04-2012, 02:34 PM
Monte666's Avatar
It was my points timing running great now Thankyou everyone this place is grwst
Old 04-04-2012, 08:16 PM
Glad to hear.
Old 04-06-2012, 07:10 PM
Monte666's Avatar
Found some weird pitting on #6 cylinder seal on the intake manifold was sucking quite a bit of air got a new performer to replace it
