Old 04-14-2012, 01:22 PM
crankshaft crankshaft is offline
Default 65 alternator location and brackets
Hello,
Where is the alternator located on a 65 chevelle with a 327, power steering, no a/c . ? what brackets do I need ? thanks
Old 04-14-2012, 10:58 PM
Drivers side of the motor. 64 to 68 use the same upper bracket on small block, and 65 to 68 use the same upper bracket on big block.
Old 04-16-2012, 07:54 PM
Thanks. So I'm just missing the upper bracket (adjuster) . As for the p/s pump,, I have the cradle bracket (lower), but is there a second bracket behind the pump ??
