Old 05-04-2012, 10:02 AM
70GARY 70GARY is offline
Default Upgrade to a 700r4?
Just got a project car. 454 with a t400 tranny thats dead. The cars gunna be a cruser with a little stop light to light action. Is there a guide to swapping transmissions. Any pros and cons $$$$.
Old 05-04-2012, 11:32 AM
Bowtie-Bri's Avatar
I went from a T400 to a 700r4. There were very few mods. Had to move the trans. crossmember back about an in. and shorten the drive shaft alittle. Thats about it. I also changed out the stock 3:31 gears to a 3:73. I'm very happy.
Brian
Old 05-04-2012, 01:34 PM
I also have a 7oor4 and like it .
Old 05-17-2012, 10:42 AM
MikesChevelle MikesChevelle is offline
WOW that is the EXACT set up I have
Old 09-10-2013, 11:10 PM
plutopjf plutopjf is offline
I swapped out my TH350 for a 700r4. Also swapped from 2.73 10 Bolt to a 3.73 12 bolt. Love it... I also had to add a rocket switch under my dash so I could control the lock up when in city driving and cut the drive shaft 3".
rocker switch... Auto spell.
Old 09-11-2013, 09:05 PM
Weazel's Avatar
Weazel Weazel is offline
I have done many 700r4 swaps, upgrades to the tranny I recommend is a TCI valvebody and a hughs rebuild kit, allot more clutch packs, with the valve body and the added packs you will get crisper firmer shifts for said stop light action
Sent from in a ditch up side down and on fire with the wheels still spinning
1972 pro touring project car (need a ton of work)
Old 09-16-2013, 09:07 AM
John's Avatar
John John is offline
what would be an expected cost of the 700R4? Something I'd love to do one day
Old 09-25-2013, 10:19 PM
Weazel's Avatar
Are you planning on doing the work? That is a major factor.
