Old 10-06-2012, 10:48 PM
Pigfat's Avatar
Pigfat Pigfat is offline
Default Help with my build
Hey all. Brand new around here and wanted to get some opinions on my build I'm doing. I have a 454 that will be bored .030 and I bought some closed chamber heads. I'm goin to put some bigger valves in the heads. I already have my cam which is a Lunati Voodoo hyd. roller which has advertised duration of 282/290, .600/.600 lift it calls for a 2500 stall and 9.75:1 compression.
So what type of pistons would you run on this? And what intake?
Old 10-07-2012, 09:42 AM
Pistons, depends on combustion chamber size. A small, less than 100cc head - flat tops. 118cc + heads - dome, around an 1/8 inch. Intake - high rise, dual plane. Edelbrock Performer RPM or something similar.
What is the duration of that cam @ .050" ?
Old 10-07-2012, 10:03 AM
mrss mrss is offline
I am not good with determining what parts will work together in the motor but I would talk to a machine shop if anybody knows they would.
Sent from my DROID BIONIC using Tapatalk 2
