Old 12-10-2012, 09:02 AM
John's Avatar
John John is offline
Default Front Main Seal
I believe I will need to replace my front seal and was trying to search it on this forum but for some reason was not coming up with any results. I suspect there is much on this but for some reason I am not doing the search correctly.
I was curious what the level of difficulty was and procedure to replace it.
I have not spent the time yet to fully confirm it's the seal and not the oil pan but the seal has always leaked so I am pretty sure it's failed. I went from a few drips to a fairly large stain on the card board I leave under the car. Just noticed it this morning. Great way to start the week.
Old 12-10-2012, 09:50 AM
not a sbc or bbc but the same idea
http://www.youtube.com/watch?v=rYTDMwxw4Ds
hope that helps
Old 12-12-2012, 04:52 PM
John's Avatar
Thanks for the video. But with a SBC, the seal is in the timing chain cover. Can that be popped out and replaced with out removing the timing cover? I have a chrome type. I’ve read elsewhere you have to remove the cover and oil pan?
Old 12-12-2012, 05:02 PM
You would need to remove the timing cover. Most chrome timing covers always leak, that why I don't use them,
Old 12-12-2012, 06:06 PM
Before replacing, try a bottle of AT-205. I have seen it fix some bad leaks.
Old 12-13-2012, 01:58 PM
John's Avatar
on a SMC motor can that timing cover be removed without affecting the oil pan?
