Old 12-27-2012, 01:13 PM
kwh1958 kwh1958 is offline
Default steering gearbox
Hello Everyone
This is my first post:
I am looking to replace my power steering Gearbox. I added shims to the power steering pump to lower the pressure to 850 psi. It help but did not fix the problem. The steering wheel has no resistant’s. I have been looking online and found a Remanufactured 700 series gearboxs for around $350.00 that is a direct fit. One of them has a Variable Ratio 16:1 at center and varies to 13:1 the more you turn. The other three are 12.7:1 quick turn 14.1:1 slower turn and the slowest turn 17.5:1. Which one would be the best fit for my 72 chevelle. Thanks Ken
72 ss clone 383 Stroker, 9.6 comp. 64cc heads, 276 Dur .454 lift 110 lsa, 670 Holley, MSD, Headers, 12 bolt 355, Vintage a/c, PS, PB, auto
Old 12-27-2012, 05:24 PM
You could go with a Jeep grand cherokee gear box conversion.
You can put in a 93-98 GC box either rebuilt from a part store or from a salvage yard. You then need a new rag joint and some cheap fittings (which can be found here, http://lee-powersteering.com/rebuild-misc.htm )
Can be pretty cheap if you do the salvage yard route or maybe $150 if you buy from part stores. All-in-all, it provides a much more firm steering feel which helps when you are at highway speeds
Check this post out, different site but a lot of info on it.
http://www.chevelles.com/forums/showthread.php?t=334534
