Old 02-18-2013, 03:14 PM
John's Avatar
John John is offline
Default Rear arm rest bases
I am in need of replacing the rear arm rest bases on my 71. Many online restoration companies sell these reproductions. I ordered a set from Ground Up and when I received it noticed several things. They don't have the detail for one. The side piece that runs up the side of the rear seat is plastic and doesn't have a way to fasten it to the base. I am sending them back. Has anyone purchased an aftermarket set and found them to be accurate?
Old 02-18-2013, 07:06 PM
You might check with James Hinshaw (Hinshaws Chevelle Parts) in Elon ,North Carolina to see if he has some nice original ones .He has a lot of good quality used parts as well as reproduction stuff. He will also tell you what repro stuff is not worth buying .
Old 02-18-2013, 11:27 PM
I still have a set of reproduction one I purchased and had painted to match my interior before I recieved them. I never used them for the same reason. Find a nice set of originals and have them painted to match your interior. No one sells one that look like the originals that I know of. What color do you need?
Old 02-20-2013, 08:30 AM
John's Avatar
I need a black set and I can't find anything original out there.
Old 02-21-2013, 11:09 AM
John's Avatar
Searched Ebay and Craigs- nothing at this time.
Old 02-22-2013, 01:12 AM
Here's some,
http://www.ebay.com/itm/1969-70-71-7...sories&vxp=mtr
http://www.ebay.com/itm/68-69-70-71-...r#ht_95wt_1331
I may have a friend who may have a set.
Old 02-22-2013, 08:43 AM
John's Avatar
Ray- that is mighty kind of you! The Ebay arm rest happens to be the passenger side and is the side I really need. The Driver side I can probably make due with (just a crack). I placed a bid so we will see. Your friend, might he happen to have a black rear side panel, passenger side? I'd like to replace that too. Thanks again.
Old 02-23-2013, 12:15 AM
So were you the winning bid? I put an email to my friend to see what he has.
Old 02-23-2013, 08:23 AM
John's Avatar
I am so mad. I've never bought on Ebay before. I was the only bidder. That is what i thought. However just before it expired someone placed a bid and beat mine by a few dollars. I had no idea i should have set up alerts. Just my ignorance and inexperience. I am still steaming about it.
Old 02-23-2013, 08:53 AM
I dont have a clue how to buy or sell on EBAY.
