Old 02-24-2013, 12:04 PM
John's Avatar
John John is offline
Default Crank Bolt removal
Any tips out there for removing the crank bolt? I am replacing the pulley and the center bolt won't budge without turning the motor. I'd rather not use the starter bump method. Any suggestion for blocking the flywheel? Vice grips? Otherwise I assume a impact wrench does well.
