Old 03-12-2013, 08:07 AM
Default alt bracket not going in place
ok so last i was playing around with my chevelle and i wanted to put my new alt bracket on but i think i did something wrong. or i have the wrong one tell me what you think please?
so do i have one for a SBC or for a BBC? I ordered it from northeast chevelle since he is kind of local to me. and i told him a 69 chevelle ss with a big block in it
Old 03-12-2013, 08:38 AM
You need a stud bolt on your intake for the alternator bracket. Not sure if this will help. Bracket looks correct.
Old 03-12-2013, 10:10 AM
lol ok so that is what i am missing! ok thank you yet again!
Old 03-12-2013, 03:43 PM
Ya, your bottom bracket is on upside down. Just need the bolt and spacer/sleeve to go through lower bracket and alt. The upper bracket normally sits down on a stud in the intake. All the others are bolts in the intake except that one. However, you have an aluminum intake and they are sometimes thicker than the steel ones so you may have to use a bolt. I know if I try to use a stud it lifts the bracket too much and it won't line up properly.
Old 03-12-2013, 03:59 PM
Good catch Hank, I didn't pay attention to that one.
Old 03-13-2013, 08:39 AM
yeah i caught that i was more worried about the top bracket but ray was right yet again
so much better then this
thanks again ray and hank!
Old 03-13-2013, 01:20 PM
That's looking really good.
Don't forget to put a washer under your top bolt that you use to tighten the tension up with.
Old 03-13-2013, 02:21 PM
i just noticed that on yours i will put one on. now on to the next issue Cooling
Old 03-13-2013, 08:23 PM
Great pics ! I am sure this will be helpful to others.
Old 03-14-2013, 08:49 AM
i hope so i know it helped me a lot!
