Old 01-12-2010, 11:15 AM
Notalent's Avatar
Notalent Notalent is offline
Send a message via Yahoo to Notalent
Default My 71 Project
I hope to have her running again by march with a whole new look and feel under the hood
Before
New Engine 496 stroker
Front Clip off and getting ready to finish tearing apart the suspension to put the new stuff on and get firewall/front half off chassis painted and the new engine/transmission back in!
1971 Chevelle - 496CI, TH400, 3.73 gears, 3500 Stall
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Custom Built Street/Strip or Racing Engines!
Old 01-12-2010, 11:40 AM
grumpy's Avatar
grumpy grumpy is offline
Administrator Bowtie Member
Bet its gonna be sweet when your done. Any idea on whats going under the hood yet ?
Dave
Old 01-12-2010, 12:00 PM
Notalent's Avatar
Engine is already done. 496 Stroker Forged internals, 10.3:1 Compression, AFR 305 CNC Heads, Air Gap Intake, Custom Hyd Roller Cam, Pro System 950HP with 1000 metering carb flowing a true 953cfm etc... Hoping to dyno next week. Should be over 600hp.
Old 01-12-2010, 06:50 PM
Looks like you are off to a good start.
Old 01-12-2010, 09:23 PM
Wow dude. That engine looks HOT!!!
Old 01-13-2010, 09:09 AM
Notalent's Avatar
Thanks guys...I wanted something a bit different as far as the looks of the engine went. I am totally stoked with it. Finished removing ALL the suspension last night...only thing hooked up still is the break lines, valves and Booster. Going to pull it tonight. Brought all my control arms/components into work today to sand blast. Tomorrow I will bust out the wire wheel, degreaser and some sand paper and getting the chassis ready to primer.
Old 01-24-2010, 04:48 PM
450HP 450HP is offline
Bet that 496 will rattle the fillings out of your teeth!
Scott
Old 01-25-2010, 10:58 AM
Notalent's Avatar
Haha.. well...through the control arms, spindles, and other little pieces in the parts cleaner here at work, than sand blasted them, primered and painted them up. Now I have to finish working on the firewall so I can finish painting the front half of the chassis and that. From there I will start bolting her all back together
Old 01-25-2010, 11:00 AM
Piece by piece. Looking good Brand...
Old 01-25-2010, 11:10 AM
Notalent's Avatar
Thanks...the firewall is going to be the "TASK" as I have to patch the cowl panel and deal with a bolt on my booster that will not come off for the life of me. Lots of wax I have to strip. I hope to have that done and painted by sunday. I really want to drop in the engine/trans by the 6th of Feb.
