Old 07-29-2013, 08:54 AM
John's Avatar
John John is offline
Default Center Link
I spotted some scratches on my oil pan and noticed it's from the grease fitting making contact with the oil pan when I've got the wheels turned fully left. My question is, is there a limit I can adjust to stop it's travel?
Old 07-29-2013, 09:10 AM
No. no adjustment. Is the center link centered between the idler arms, roughly same amount of threads showing on both sides? Are pitman and idler arm straight front to back with steering wheel centered? Not likely that it's off much but it is possible to shift the center link to one side or the other via the idler arm adjustment. Of course changing it now would throw the steering wheel off center.
Old 07-29-2013, 10:56 AM
John's Avatar
Good questions Hank. I will check that and get back to you. Thanks for the response.
Old 07-29-2013, 12:29 PM
Where are your grease fittings located?. Mine are on the inward side toward each other and would not be able to hit the oil pan.
Old 07-29-2013, 02:59 PM
EXACTY!!
Both INNER tierods will have the grease fittings on the very end of the tierod.
OUTER tierods have DOWNWARD facing grease fittings but none come close to the oilpan at full lock to lock.
Me thinks you've got outer rods at inner position.
Old 07-31-2013, 12:31 PM
John's Avatar
Now wouldn't that be some bull$*@!
I can definitely say they stick straight out the side and point to the oil pan.
Old 07-31-2013, 08:58 PM
I will look at mine. They may point toward the oil pan some when the wheels are straight. Mine look like this.
http://www.ss396.com/mm5/merchant.mv...ct_Code=ES-681
Edit:
I turned my wheels both left and right and there no way my tie rod ends even come close to the oil pan. Are you running a stock oil pan? If so is your steering centered both left and right? Also when I turn my wheels my center link goes down away from the oil pan.
Left
Right
Old 08-01-2013, 08:49 AM
smoke' em II's Avatar
FWIW, original inner tie rods had the grease zerk fitting on the ends of the tie rod, a lot of the current replacement style inner tie rods (MOOG, and current GM Delco replacement inner tie rods) have the grease zerk screwed into the back of the tie rod.
ACES #08588
1970 Chevelle SS
1970 Olds 442 Survivor
Old 08-01-2013, 09:56 AM
They are available both ways still
Old 08-02-2013, 05:12 PM
John's Avatar
it's a stock pan. I'll have to spend some time with it trying to sort out the cause. The steering wheel is darn close to being cented. Very strange. Not sure what will be involved. I don't like the idea of it making contact with the pan and have to fix it quick
