Old 08-05-2013, 07:30 AM
John's Avatar
John John is offline
Default header gaskets
I've had a header gasket leak I've been wanting to fix so this weekend I removed the gasket to take a look at it. It appears the head (AFR) has square ports, the header is more an oval port. What would be the best gasket to use?
Right now it's got a copper gasket, with a raised lip on one side.
Old 08-05-2013, 07:54 AM
hmmm that is interesting. i thought if you had square ports you need a square port header as well. i cant help you on that one wish i knew more sorry man
Old 08-05-2013, 09:35 AM
John's Avatar
That is what I though. My suspicion is the original owner wanted to use what he had and made due.
Old 08-05-2013, 10:21 AM
From what i have seen...most heads have square ish ports
and most headers are oval...headman hooker etc.
perhaps AFR recomends a gasket.
Ive had good luck with felpro 1404 or 1405
Old 08-05-2013, 11:17 AM
Copied from AFR site...
Old 08-05-2013, 04:24 PM
John's Avatar
I called AFR-that is the gasket they recommend. Thanks.
Old 08-05-2013, 10:50 PM
Let us know how it works out.
Old 08-06-2013, 07:02 AM
That's what I've seen. The intakes are either square or oval but the exhaust ports are square.
Old 08-13-2013, 06:59 AM
John's Avatar
Will do. just ordered it and will get it installed this weekend.
Old 08-19-2013, 07:12 AM
John's Avatar
Anyone using a copper gasket for the header?
