Old 09-26-2013, 02:37 PM
Default Pro6Ten Polished A/C compressor & BB 2nd Design Brackets
I'm guessing most of you frequent both forums, but for those who don't...
I removed the Pro6Ten compressor from my car last night to replace with a serpentine drive system - if I could have this compressor with a serpentine pulley I would not be selling.
The compressor was purchased on 8/28/2012 from Oldairproducts for $415.00.
The brackets are all still attached to the compressor (may need to remove for shipping purposes) so all you need to do is bolt to your head & intake!
Brackets were powder-coated gloss black. The over the valve-cover bracket was clearanced so that it would clear my "cheater" valve covers but it is hardly noticeable. New brackets from Ground Up cost $224.95 so in total this is a $639.95 package if purchased new, not including cost to powder coat.
$300 + actual shipping (compressor is aluminum and 1/2 the weight of the factory beast but not still light so please keep that in mind.)
I will take photos of compressor as it sits right now if you would like but this photo was from last night just before I began taking the front accessory drive off.
I do have the line-set as seen in the below photo and can include for an additional $50 (179.95 new) if you want/need it. This takes you from your POA to the condenser, joined at the rear of the compressor.
Because of the awkward size of the lines it may require either a much larger box or two separate boxes to ship.
