Can anyone help with identifying what my rear axle and gearing is? The picture maybe is CCA 0929 B which is a 3.08:1 10 bolt. Could the picture show a CGA which is 2.56:1 10 bolt for the 350? I originally have a 350. The second letter isn't clear or stamped entirely.
![]() It also looks like my ring gear is positraction which could have been changed out at some point I guess. ![]() Sent from my SAMSUNG-SGH-I337 using Tapatalk Last edited by caljon88; 02-25-2014 at 08:42 AM. |
Looks like CCA, but if it's now a posi then the gears most likely have been changed. Looks like you have some ID numbers on your gear. Count the turn of the wheel to 1 full turn of the driveline will tell you the ratio
The "two" C's don't look the same though, the bottom loop comes up higher than the first one. Looks like it could be a badly stamp G maybe? You can see it says the 1 GM 3xxx.... Not sure if that means posi or not.
Sent from my Nexus 7 using Tapatalk |
