Old 07-07-2014, 06:26 PM
Question Break-in oil?
I'm wanting to get the motor started soon and was wondering if Rotellat would work as a break-in oil for a roller motor? None of the local parts stores sell break-in oil. Has anyone used it for that? I know since it's a it's not as critical as if it were a flat tappet.
Old 07-07-2014, 07:17 PM
Being hydraulic roller, I wouldn't worry too much. You can buy zinc additive at most parts stores if you are still concerned. Just make sure you prime the oil pump before start up.
Old 07-08-2014, 09:48 AM
I think GM dealers still have EOS (engine oil supplement). A different name now but the same stuff. Like carpoor said though, a roller engine shouldn't require it.
Old 07-08-2014, 12:26 PM
I used Rotella/Delo oil exclusively in an 800+ HP 540.
After 3 years of many, many street miles and numerous track visits, although having no issues, I tore this engine down for a freshening up.
Internals looked brand new.
Re-ringed STD, new STD bearings, replaced solid roller lifters (.800"+ lift) and valve springs...back together it went.
Old 07-08-2014, 07:32 PM
if it matters i used royal purple break in oil on mine
Old 07-10-2014, 09:59 AM
LUCAS break in oil additive and regular Castrol oil
