for your chevelle of course? I am get sad knowing that i have to hang the keys up on the key rack for a while
but i am looking forward to doing some upgrades/new installs. Here is my list so farFront seats. reinstall my carpet i messed up somewhere i have a big gap on my passenger side. New door panels Glove box since i don't have one repaint my glove box Dash Pad Install my heater correctly have my rear end over hauled rear disc brakes and if i am not dead broke by that time try to have my car professionally painted ![]() So what are your plans??
2005 dodge magnum daily driver 1988 mazda rx7 LS6 swap 1969 SS work in progress |
Wiring in functioning and tested.
Dash in and complete. Sand and buff. Weather stripping in. Side windows in. Assorted chrome I do have put on. Lay vinyl top on car let it form to the roof a while until it gets hot enough to put on. Order interior with luck.For the spring activities. Assuming the eagle sh..s |
Find a good auction in the south.
Im just planning on a good cleaning ,wax and detail and then drive it some more .I do need to get it to the transmission shop for the right speedometer gear in the 700R so The speed registers right.
John |
I'm hoping to get mine finished this winter in time to be able to drive it in the spring.
Justin ![]() Projects: 70 Chevelle Malibu http://s132.photobucket.com/user/qua.../70%20Chevelle |
Engine transplant. This stock small block just ain't doing it for me!!
2017 Camaro RS -217 cu in 365 HP w/8 speed auto 1967 Camaro SS -5.3L LS w/4L60E & 4.11 12 bolt 2019 Cadillac XT5 3.6L V6 w/310 HP & 8 speed AWD |
Not making plans... Because nothing goes as planned.
1972 SS 454 Chevelle LS5/M21/12 bolt 3.73 posi 1969 Malibu COPO L72/M20/12 bolt 3.31 posi 1968 Malibu LQ9/4L80E/12 bolt 3.73 posi |
AMEN TO THAT !
Looking to find a good deal on an electric fuel pump. Looks like come spring when I get it out of storage I will need to replace it.
Dash work, fix gauges that stop working??????
Looking for an original dash bezel to restore. Motor oil leak Might also put in a new wiring harness and fuse box while I have it apart again.
Ray 1970 SS Chevelle Van Nuys Built Last edited by shadowgray396; 10-28-2014 at 08:15 PM. |
