Go Back   Chevrolet Chevelle Forums > Chevrolet Chevelle Shopper > Chevelle Vendors Section
Old 01-27-2010, 10:18 AM
Notalent's Avatar
Notalent Notalent is offline
Send a message via Yahoo to Notalent
Default New 496ci with 781 Heads 560+HP/600+TQ
Just did an engine for a customer and being that its a semi popular build and alot of people like to know ahead of time if there engine will make vacuum or not this would be a good base line.
Specs:
496ci 9.7.1 Compression
Scat 4340 Forged Rotating assembly
781 Heads with bigger valves and mild porting
Hyd Roller Cam 236/242 @ 50 .620 lift on a 112LSA
Edelbrock Air Gap Intake
Edelbrock Thunder 800cfm carb
Vacuum = 12" @ 1000RPM, 11" @ 950 RPM (take from carb).
http://www.youtube.com/watch?v=UMy3kAa0Wbo
1971 Chevelle - 496CI, TH400, 3.73 gears, 3500 Stall
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Custom Built Street/Strip or Racing Engines!
