Old 03-01-2016, 05:20 PM
Default trany nightmare
Been working on body...lots of sanding etc.
Today i tried to back the car outa the garage to do more body work
I have no reverse...no nuetral.....its stuck in drive.
The linkage is correct and no matter where i put the shifter the car goes
forwards.
This is a newly rebuilt trans with all the good stuff in it
redline clutches...colene steels you name it its in there.
Yesterday it was fine.....today WTF.
Old 03-01-2016, 05:39 PM
Sounds like my luck .
Old 03-03-2016, 07:20 AM
Rattler's Avatar
Rattler Rattler is offline
Is the fluid burnt? Sounds like it overheated and the clutches are welded together if your linkage is all fine.
Old 03-03-2016, 08:57 AM
Found the problem.
nut on the inside of the selector shaft backed out and popped of the S link.
simple fix. drain fluid..remove pan etc.
