Old 03-03-2016, 05:29 PM
Default Saginaw 3 speed problem
Installed rebuilt Saginaw 3 speed. Trans will not down shift from second to first while moving. Trying to downshift to first results in grinding noise. However, if car is at a dead stop, with engine running, if I shift into reverse and then into first gear it engages easily with no grinding. If I shut the engine off it will shift easily into first.
Any ideas ?
