Old 12-04-2018, 09:35 PM
kevinw kevinw is offline
Default need help in decipering these engine id numbers
Hello. I have a 69 Malibu 350. engine is in shop for overhaul. anyway, while mechanic had all of it torn down, I pulled numbers off all these parts. what do they all mean? car is a matching numbers 350.
block 3932388
6160
T 13
conv 1
ID 19B375144 To4IIHF. I know my VIN is 375143, so it matches except last digit, block is a 4, my vin is a 3
388
37TG14
the above are all off the block. what do all those numbers mean?
the Heads. one side is 393441 , then A149 then GM 9
the other side is 3932441 then A 169, then GM 9 , so the A number is different from the other side
would this be a 2 or 4 bolt main?
and why would last digit on block be off from the VIN?
all your help would be appreciated!. the engine is bored 30 over, and I am just having basic stock cam, crank, pistons put on to keep costs down.
I have the original carb and intake and exhaust manifolds that came with car also , but I run long tubes with alum intake and Edelbrock 600 carb.
thanks again!
K
