Old 04-19-2020, 10:57 AM
mhall mhall is offline
Default 469ci BBC
Great Bracket or Pro Street motor
469 ci BBC (4.320 bore / 4.000 stroke)
4 bolt main
Scat 4340 crank
Scat H-Beam rods w/ ARP 2000 rod bolts
SRP Pistons
12.9 compression
Brodix BB2 alum heads
Comp roller cam
Moroso Pan
Moroso HV oil pump w/ welded pickup
Comp valvetrain
Comp ultra pro magnum rockers
Stud girdle
Hex adjust double roller timing chain
Fluidampr balancer
Brodix HVH intake - 4500 flange
MSD distributor & plug wires
Flexplate
Fresh build / Professionally machined
$7000 Intake to Pan
901.497.9366
