Old 05-17-2021, 10:26 PM
denson denson is offline
Default 1970 12 bolt
1970 Chevelle 12 Bolt housing includes the bearing blocks, axles, and rear cover. Also have new in box Eaton series 4 posi and new in box 4.56 Ring & Pinion set. If i dig deep enough i probably got the rear brakes also.
The 1968-72 Chevelle housing is only 3/8" wider per side compared to 1964-67 Chevelle housing...and will install it either series identically according to Google info.
Asking $1200 at 57703.
Also have for 1965 Chevelle brake-clutch pedal assy, NIB front end rebuild kit, and NIB Poly body mount cushions.Click image for larger version
