Old 06-13-2010, 09:16 PM
Exclamation Help my car won't start!
Took a 30 minute cruise in my car,pulled in my driveway to dust him off and an hour later he wont start!Backfired throught the carb and that's it! First problem in 3 years,I hope I can get him in the garage tonight,my drive has a slite grade going in.Crap
Old 06-13-2010, 09:25 PM
OH NO.....
Hope you can get it into the garage. You will find the problem and fix it. Let us know what happened.
Old 06-13-2010, 09:34 PM
My neighbors came over we got him inside.It keeps popping through the carb,and cranking like a car that has a wet cap. Did it jump time?
Old 06-13-2010, 09:39 PM
Grumpy and I were sitting here when I read him your first post and he made the comment that maybe your timing was off, then you post your last post.
Let us know.
Old 06-13-2010, 09:42 PM
Points or HEI set up in the distrubutor?
It sounds like timing, but it could be points.
Old 06-13-2010, 09:43 PM
How can a car jump time after running so great? I don't understand that.....
Old 06-13-2010, 09:44 PM
Points or HEI set upin the distrubutor?
It has an Accel hei system.
Old 06-13-2010, 09:49 PM
I was driving it nice and easy tonight. It had sat for about a month and fired right up tonight. I am too tired to look at it now,at least it's in the garage.
Old 06-13-2010, 09:50 PM
There are mega pressures going on at the timing chain. It could be nothing more than good luck that you had it at home instead of 30 miles away.
That would be GOOD KARMA my friend.
Yes,we already thought of that!!!!
Old 06-13-2010, 09:51 PM
I agree it can only be one or the other. Also check the distrubutor bolt to make sure it is tight. If it's not tight your distrubutor can turn screwing up your timing also.
