Old 06-16-2010, 02:43 AM
720kid's Avatar
720kid 720kid is offline
Default 355 w/vortec heads, AC re-install
First off, hello members...no section for AC so ill post here.
I am trying to figure out how to re-install the AC in the '72 chevelle since my engine swap, A/C worked fine before the swap, the new engine is a 355 with vortec heads from blueprintengines
http://www.blueprintengines.com/popu...specs&pc_id=24
I do have the original unit and everything was left in place to hook up the AC again. I have conflicting info from two different mechanics.
I was originaly told by the guy who did the new engine/tranny install that the previous genreration Camaro IROC came with the same heads and AC unit that i have, so all that wolud be needed was to locate a mounting bracket.
I have also been told that GM changed to a different style AC unit and that the only way to use my current AC unit is to have a bracket made.
- Could anyone comment on this and let me know if the info above is true, if so all i would need is a bracket (from where?)
or should i just upgrade to the 134a Sanden kit below?
http://www.classicautoair.com/GM_San...onversion.html
