Old 06-18-2010, 11:55 AM
Default Steering Wheel solution
I have a reproduction '69 Rosewood wheel for my car, but at 16" dia, it's WAY too big for autocross... I also have a 14" dia Grant GT wheel that I have been swapping in for autocrossing, but it's a big PITA as it takes using a steering wheel puller to pull the both of them.
So I started my search, and found that a lot of aftermarket wheels use the same 6-hole 2.75" bolt pattern that the GMs do, including some really lame JDM "type R" wheels. ...so I bought one anyway.
put it on my Rosewood base, and it fits... but the holes are "clocked" wrong. So if I want to use it, it'll be 15deg off-center. See the hole pattern below for comparison...
Well, that stupid looking horn button I'm not using, but it made a good fixture to drill some new holes in the right orientation.
Now I can swap steering wheels in just a couple minutes with only a phillips screwdriver, and that ugly yellow band around the top of it will easily show me wheel-position in my in-car autocross videos.
