Old 11-05-2010, 12:46 PM
jnd's Avatar
jnd jnd is offline
Default Body bushings
I have a 69 chevelle running tall spindals with 2inch drop and 2inch drop springs. i want to get alittle lower and am currently workiing on a new frame narrowing or notching the rear to fit 335's. i was thinking about removing the body bushings and replacing them with a few washers welded to the frame. i understand i would have to deal with trans tunnel, plumming and steering shaft clearances. just wondering if anyone has ever lowered a car this way. i started out looking for a soild bushing 1/4 or 1/2 the size had no luck but figured i could achieve the same results with the welded washers. any thoughts or suggestions? thanks Joe
