What a lot of people overlook is fuel and timing. You said right after carb and timing work, it started to heat up. What exactly did you do? If the timing is too far advanced it will cause heat and if your engine is running too lean, it can create A LOT of heat. Fuel as a liquid helps cool the heads down. Check these two things and see what you find.
