#11
Not a whole lot of progress worth posting. Right now there are lots of little things that are being done that really seem minor in the grand scheme of things but are required to get everything going. For example, bending transmission lines, getting all the appropriate fittings for things like the trans cooler & fuel pump. Waiting on the lower alternator bracket to come back from powder coating.
Pulled the old booster & master off today & bolted the new booster in place. Looks much better! Started the car and checked oil pressure today. Everything looks good! Let the car run for about 1 minute. I thought I had a video but apparently I either didn't press the record button or I accidentally erased it. Tomorrow/Friday work should begin on the suspension. The 1350 Yokes from Denny's Drive shaft will arrive tomorrow as well so hopefully we can get the drive shaft measured and ordered. Technically the only thing the car needed today to go drive would have been belts, the lower alt. bracket and the drive shaft installed. That'll still be a little bit out but it is that close. Today's photo
Eric 496 cu. in. "cruiser" Assembled & tuned by Mo's Speed Shop - Dallas, GA |
