#12
So now knowing that i started to come up with a list of all the parts and things i need to get and this is what i came up with.
Chevelle list Rear end Parts needed total $369 Drum brakes spring kit $43 http://www.ss396.com/mm5/merchant.mv...DRUMBRAKEPARTS wheel cylinders $20x 2= $40. http://www.ss396.com/mm5/merchant.mv...=WHEELCYLINDER e-brake cables $140 http://www.ss396.com/mm5/merchant.mv...e=PARKINGBRAKE wheel studs $16 http://www.summitracing.com/parts/RNB-610-157/ Shocks $130 http://www.ss396.com/mm5/merchant.mv...PENSION Front end Parts needed $355 Front brake rebuild/replacement parts $298 Brake booster and master cylinder $170 http://www.ss396.com/mm5/merchant.mv...STERMASTERKITS brake calipers option 1 $38 http://www.summitracing.com/parts/AAZ-18-4039/ http://www.summitracing.com/parts/AAZ-18-4040/ option 2 $170 http://www.ss396.com/mm5/merchant.mv..._Code=CALIPERS rotors Option 1 $120 http://www.ss396.com/mm5/merchant.mv...ry_Code=ROTORS option 2 34 x2= $68 http://www.summitracing.com/parts/RSD-BR02C/ brake pads to many options to list when the time comes I will select the right one. Wheel bearing $22 http://www.summitracing.com/parts/RAT-12126/ Front suspension parts Front springs $57 http://www.summitracing.com/parts/MOG-6319/ Wiring $220 Front harness $161 only because mine is in rough shape and i am not sure if i am going to take the time to rebuild it or get a new one. http://www.ss396.com/mm5/merchant.mv...uct_Code=18015 sending unit harness $19 (mine is missing) http://www.ss396.com/mm5/merchant.mv...uct_Code=28540 Gauges $40 (just so i can keep track of everything and to fill the holes on the block and heads) http://shop.advanceautoparts.com/web...7CGRP2032_____ Tires $400 (guessing I still need to figure out what tires size I need/want) Grand total of $1344 this is not an exact number this is just an informative way to look at the amount I would need to save up/spend to get it on the road. so what do you guys think? am i off to the right start? anything you can think of that i am missing?
