Old 07-15-2012, 08:45 PM
The windows on these cars are very easy to pry open a little so that you can use a coat hanger to pull up on the door lock. If nothing else, do yourself a huge favor and call a tow company and pay the $50 or $60 to have them open your car rather then replacing a window. I bet they have your car unlocked in 5 minutes or less.
The tow companies or police have an inflatable wedge that gets jammed in between the window and frame. Then when it is pumped up it creates a large enough gap to slide a rod-mechanism into the car which will either pull up on the lock or door handle.
