Old 10-06-2012, 02:07 PM
Originally Posted by fleming23 View Post
Have you considered swapping in a steering box from a Jeep Grand Cheorkee?
You can put in a 93-98 GC box either rebuilt from a part store or from a salvage yard. You then need a new rag joint and some cheap fittings (which can be found here, http://lee-powersteering.com/rebuild-misc.htm )
Can be pretty cheap if you do the salvage yard route or maybe $150 if you buy from part stores. All-in-all, it provides a much more firm steering feel which helps when you are at highway speeds.
I've done this JGC conversion on about a dozen Chevelles...including the '66 Sedan presently in my shop.
Awesome swap!!
The box MUST be from a '93-98 Jeep GRAND CHEROKEE only!! And the rag joint needed is P/N Lares 200 found @ Advance Auto.
