Old 11-05-2012, 04:31 PM
What's wrong with the alignment? There are no shims used behind the hinges. There are shims used behind the fenders which will move the fender and hinge in or out. Up/down, front/back is accomplished by rotating the hinge on the fender or sliding the hood on the hinge. The bolt holes in the hinges are slotted so you can make these adjustments.
