Old 11-15-2012, 09:10 AM
John's Avatar
John John is offline
Default Vinyl dye
Question- I have a discoloration in one of my door panels. The panel is black, and some sort of solvent looks to have been dripped onto the vinyl and took the black out of it in several areas. I'd hate to replace a perfectly good panel. Is there a dye kit I could use to fix this?
Old 11-18-2012, 07:25 AM
SEM makes a spray paint for vinyl, soft plastics. Most of the restoration suppliers will have it. You'll also find it at some auto parts stores and automotive paint supply shops.
Old 11-18-2012, 03:06 PM
You could go to a upholstery shop and see if they can touch it up for you.
Old 11-19-2012, 11:49 AM
John's Avatar
Thanks Hank-I spoke to SEM and it sounds like exactly what I need.
Old 11-19-2012, 05:41 PM
John I have used the spray with good results. Good luck.
Old 11-20-2012, 11:47 AM
John's Avatar
The panel has some chrome detail, which I'd need to tape off. What tape is recommended for this very fine detailing?
Old 11-20-2012, 06:09 PM
Blue painters tape and steady fingers .
