Old 12-24-2012, 02:35 PM
Bill ,what wheels are you using next and where are the pics of them on the new wagon ?
Old 12-29-2012, 11:47 PM
finished cleaning up the garage some and finally opened my driveshaft box, just need to order the yoke and u joint but while i was at it i put the new valve covers and air cleaner on just to get it out the living room..lol
and got the last of the brake parts on
Old 12-30-2012, 10:28 PM
Looking sharp
Old 12-31-2012, 12:32 AM
Weazel's Avatar
Weazel Weazel is offline
I started working on it
Gonna be a long road
Sent from in a ditch up side down and on fire with the wheels still spinning
1972 pro touring project car (need a ton of work)
Old 01-04-2013, 09:57 AM
It was 27 Degrees out this morning when the sound of a big block filled the morning air.
Drove mine to work for the first time in a few weeks! So glad I don't live up north!!
Old 01-09-2013, 08:37 AM
Noticed a small spot of oil in the garage under the car and assumed something was just a little loose and needed tightened - oil spot was not large enough to cause concern really.
Well I crawled under the car yesterday and did some cleaning up/wiping down and checking all the various bolts that might need re-snugging. Nothing was obviously loose and the oil appeared to have no starting place except the bottom of the pan.
So I wiped the pan down and continued cleaning up headers and other various areas that get road grime on them when I noticed a line of oil slowly making its way back down the pan. That is when I noticed the small hairline crack right on the front side edge of the oil pan.....
iPhone doesn't really show it, but up close you can just barely see a spot where the paint is cracked right on the edge (nearest the front cross-member.) Not sure if the previous dent weakened the area or what. Hoping it can be tigged in the car - don't really want to replace the pan since the motor was JUST out of the car!
Old 01-09-2013, 10:21 AM
Damn Eric...your luck!!!
Any idea on how that pan got dented? From the latest R & R?
Old 01-09-2013, 10:50 AM
Tell me about it...
Not sure on the dent really. I thought I remembered it having a few small dents when originally installed that were hammered out a little. The paint is not scuffed, scratched or anything to indicate it was hit when dropping it in the last time. The photo shows a dent and spot where the old paint flaked but the new paint is clean. I know one of the header tubes contacted the asphalt coming down the 75S/285E ramp but the pan looks clean so I wouldn't think that did it.
Who knows, hopefully the guys at Mo's can tig it up for me with little issue. Not too worried about it.
Old 01-09-2013, 11:31 AM
If not for bad luck you would have none ,hope its an easy fix.
Old 01-09-2013, 04:21 PM
I too hope it is an easy fix. I think all of us have felt this way at one time or another.
