Old 03-20-2010, 06:24 PM
Mitchell Mitchell is offline
If I'm reading and understanding correctly, you want to know where to measure the amount of transmission fluid in the pan. There should be a dipstick for the automatic on the left side rear of the engine when you are facing it. Remove this, wipe the end clean and reinsert into the tube. The engine should be running. Remove the dipstick again and see if you need to add fluid. If you do, Dextron II is what I use. Do not use engine oil.
You should upgrade to dextron III (you don't have to but GM recommends it if I'm not mistaken.)
SBC350
L31 Vortec Heads pocket ported with stock valves, Comp Cams N+L79-H, .462/.468 valve lift, 229/236 duration @.050, 112LSA, 9.6:1 compression, Summit Stage One Vortec intake manifold, Holley 600cfm street carb W/ vacuum secondaries
