Old 07-27-2010, 12:29 PM
As stated previously. Commonly black to ground. Red to 12volt switched power and the green to tach signal.
Is this what you did?
From what I can understand of your connections.your grounding the power and power to ground. Still dosent explain why no cranking. How did you determine what wires you spliced into?
Old 07-27-2010, 04:12 PM
Saskuatch83 Saskuatch83 is offline
From the directions i got they said to splice into the red wire coming from the ignition. I also unhooked what i did... still no cranking, its at the shop now.
Old 07-27-2010, 05:35 PM
Have you checked all the fuses? You're going to have to trace starter voltage, S terminal on starter, from the starter back through the neutral safety switch, ignition switch then fuse block or the other way around.
Old 07-28-2010, 05:59 AM
I am betting blown fuse. From putting ground to power. Be interested in hearing what your shop finds.
Old 07-28-2010, 02:20 PM
Rattler's Avatar
Rattler Rattler is offline
If the ignition is no longer hot when on then you more then likely just blew a fuse.
Old 07-28-2010, 03:11 PM
Is there a fusible link that he could have cooked by crossing the wires?
Old 07-28-2010, 03:36 PM
It's possible. I believe the main splice/distribution point on the 72 is from the starter. Battery cable to starter then I believe fusible link to main power feed. He should have absolutely nothing if he blew the fusible link. No lights, accessories, nothing.
