Old 07-25-2010, 10:46 PM
Saskuatch83 Saskuatch83 is offline
Default Please help gf is mad
Hello, so after a successful day working on the car i decided to hook up the tach. I found some directions online, here is what i did.....
Ran black wire from battery, hooked to tach
Green wire to distributor
Spliced into red wire from ignition harness and hooked to tach
and viola the car wont start, everything has power, radio horn lights etc but wont turn over.... Please any input would be greatly appreciated, also please be specific because im new at this stuff .. thanks!
Old 07-26-2010, 02:35 PM
I am not sure. Am trying to find the answer for you. But I know someone else will beat me to it.
Old 07-26-2010, 03:10 PM
Won't crank, or won't fire? Seems really odd if it won't crank...
If it cranks, but won't fire, I'd be looking at the distributor to make sure you didn't unhook something important there when you were hooking up the tach.
Old 07-26-2010, 03:55 PM
Black wire to battery? Black wire is typically ground, if you wired to negative post on battery that's good. Could also connect to any good ground under the dash. Green to distributor, tach terminal on HEI or negative on coil of points system. Red wire to anything hot when car is in run, their is a IGN connection in fuse block that is a good point.
You didn't mention what type car, year, type of ignition and type of tach so I'm making some assumptions that may not be correct.
Old 07-26-2010, 04:27 PM
Is your girl friend still mad?
Old 07-26-2010, 11:50 PM
Sounds like Hank has you covered. Good post as usual, Hank.
Old 07-27-2010, 02:46 AM
Sorry, 72 chevelle, not sure of ignition, some cheap tach that came with car.... I dunno i checked voltages, no voltage when ignition is turned no voltage between ground and reg ign wire. Car wont even turn over grrrr. I have it booked to b looked at on wednesday so we will see.
Old 07-27-2010, 10:07 AM
Man, just go back through and retrace your steps. I'll bet you find what is wrong yourself. Check your connections, and make sure nothing got loosened when you were trying to put the tach in.
Old 07-27-2010, 12:15 PM
I'd just unhook what you hooked up and see if that corrects it and if it does you can kick yourself then....ask me how I know...ha.
Word of advice...never make to many changes at once as if anything goes wrong you can just undo it or concentrate on what you did to correct it.
Old 07-27-2010, 12:20 PM
X10,000 Complete truth there, Ric.
