Old 08-07-2010, 10:51 PM
70ChevelleRagtop 70ChevelleRagtop is offline
Default Lots of misc 68-72 parts
Time to clean things out...this stuff needs to go!
Automatic steering column (non-tilt) fits 70-72
Transmission cross-member for 68-72 El Camino or convertible A-body (fits boxed frames only)
Front bumper brackets off a 72 El Camino
Upper and Lower front A-Arms
Front swaybar
Front Spindles with Drums (can be modified to accept discs)
Master cylinder and power brake booster off '72
Power steering gearbox for 68-72
Charcoal cannister for 72
Washer fluid bottles
Windshield bottom stainless trim
Stainless trim for top rear of fender at A-pillar
Brake pedal assembly (for auto)
Interior A-piller steel trim
Interior - Drivers side plastic toe-kick (this goes over the top of the carpet and mount onto the firewall behind pedals)
Sunvisors for '69
Wing window assemblies - fit 68-70 2-door sedans and 68-72 El Caminos (complete and working)
Misc A/C ducts for 70-72
Other misc parts and brackets - let me know what you need. I may have it.
Smugglers box lid for El Camino
Drive shaft for El Camino (turbo 350 yoke)
Rear El Camino frame brace
Other misc parts.
Also have:
Mallory dual-point distributor for SB or BB Chevy
Holley 780 vacum secondary carb freshly rebuilt - never run
Holley 780 vacum secondary - this is a GM service replacement carb - core quality
AC Delco #868 fuel pump - correct for certain big block Chevelles
Misc power steering pumps for Chevy's
'72 CE 402 block
Dana
1970 Chevelle convertible
Fresh 454 with 291 heads, Lunati 60204, and 569 intake waiting to be installed. Turbo 400 with street/strip BTE stall converter and 4.10.
Old 03-12-2011, 12:21 PM
gmguy1993 gmguy1993 is offline
any hood hinges for 70-72 chevelle,or 64-67.?? thanx hood latchs/??
