Old 08-14-2010, 04:48 PM
Warputer's Avatar
Warputer Warputer is offline
Default Front end sits high....
Is it normal for the front end to look higher than the rear? What's the easiest fix? Coil spring swap? See pic...
Chris
69 4-Door Malibu
Old 08-14-2010, 06:26 PM
Rattler's Avatar
Rattler Rattler is offline
Coil spring swap or drop spindles will lower it for you. There are also coil-over setups that you can swap in and give you full ride height adjust-ability.
Old 08-14-2010, 08:44 PM
That looks a little higher than usual.
Share some details about it... all the weight on the car yet? what springs are in it? (BB or SB?), were the control-arm bolts tightened with the weight of the car resting on the suspension, or with the suspension hanging?
Old 08-24-2010, 03:25 PM
Warputer's Avatar
Weight wise....only thing missing in the front is the inner fenders & the battery has been relocated to the trunk.
Did a previous owner install those little twist expanders or the bracket expanders in the front coils?
I spoke with the previous owner & went thru the "book" of receipts that came with the car & the entire front suspension seems to be all original. The only change to the front end is they installed a disc brake conversion.
Chris
69 4-Door Malibu
Old 08-25-2010, 01:37 PM
What Derek was asking is this. Was the front end up on jack stands, etc. with the front suspension hanging down when the control arm bolts were tightened? This can 'pre-load' the suspension and the bushings will hold the car up. If so then set the car down on the pavement and loosen all 8 bolts. You may want to bounce the front end a few times to help it settle. Then re-tighten the bolts.
Old 08-25-2010, 02:50 PM
Rank Rank is offline
There is definatly something going on there ... but damn that is a nice mor-door! ... check in the truck, maybe Jimmy Hoffa is there LOL
Was it originally a big block car and they put in a SB?
Old 08-25-2010, 04:26 PM
Warputer's Avatar
Thanks....I will try this!
No...I have the original papers from the dealer....came with the same 350 that is in it.
Chris
69 4-Door Malibu
Old 08-27-2010, 08:16 PM
ss1970chev454's Avatar
ss1970chev454 ss1970chev454 is offline
sharp car! It does look like it's setting higher than normal but I like it. You could always cut the front coils. But, I would be tempted to raise the back a tad.
TC # 4348
ACES # 6175
NCOA # 10479
"220...221 whatever it takes."
Old 08-27-2010, 08:51 PM
Warputer's Avatar
This has crossed my mind.....does the replacement coils in the magazines that are labeled as "HD" add any extra height? If not, what other options are there for raising the rear?
Chris
69 4-Door Malibu
Old 09-27-2010, 09:01 PM
Warputer's Avatar
I guess my next question is.....how much of the coil needs to be taken off to get a 2" drop on the front.
As for the back.....which would work out better, coil spacers or the old timey air adjustable shocks?
Chris
69 4-Door Malibu
